Unable to edit block in place.
Message 1 of 11
Hello firends.
I am using autocad 2017 and I am unable to edit block in place.
I am doing select block, right click and them "edit block in place."
It is selecting but its not going inside the block. Block is remain block un editable.
When I copy and explode it, its only one block I can modify like a normal drawing.
Please help.
Replies (10)
Message 2 of 11
Alfred.NESWADBA
welcome @Anonymous.autodesk.com!
Does the option "Block Editor" work?
Is it a special type of block (dynamic block, XRef, ...)?
If it's specific to that block (while other block types can be modified) it might help to upload this drawing.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 3 of 11
rkmcswain
I suggest using BEDIT instead of REFEDIT.
But back to your complaint. So you select the block, then right-click and choose Edit Block in Place?
Like this?
After you select this option, do you get this dialog?
R.K. McSwain     | CADpanacea | on twitter
Message 4 of 11
Yes, I did those steps but still can't edit the block in place, also only few blocks having this problem other new created blocks can edit in place.
Please help for solve this problem, thanks very much.
Message 5 of 11
pendean
Community Legend
Community Legend
Post a screenshot of your ABOUT command pop-up please.
Message 6 of 11
When you create a block, make sure you have the box at the left bottom, "Open in block editor" checked.
Message 7 of 11
cadffm
Hi @Anonymous
please answer the questions . it is your problem, so be kind to  reply 🙂
We can start where the thread started 4 years ago:
Please select one blockreference, start command EXPLODE, read what ACAD say [F2]
and if you can read only the feedback "1 found",
then select one object by pick selection and start LIST command.
What is Acads answer? [F2]
Sebastian
Message 8 of 11
Kent1Cooper
Is the Block made up of only a nested other Block?  That's what the description in Message 1 sounds like [different User, so maybe your situation is different].  You should be able to tell from the second image in Message 3, which would have more than one entry in the Reference name: box -- the "outer" Block name and the "inner" nested one -- and you can pick the nested one to edit that.
Kent Cooper, AIA
Message 9 of 11
Solution
This error is cause by the Dimension overrides.
To resolve the error
1. On the command line, enter BEDIT
2. Select the affected block.
3. In the Block Editor, enter DIM, to put you in Dimension mode.
4. Enter Override
5. When prompted, enter C to clear the overrides.
6. When prompted, enter All to select all objects.
7. Exit and save the block.
Now, the REFEDIT command can be used on the block.
Message 10 of 11
cadffm
Hi rahulpingale37,
thank you for sharing, but a dim override shouldn't be a problem and i can't reproduce it with my
sample block and program version.
There must be another thing too in your case, for example corrupt data or a special item, whatever.
I like to see and learn, please share one sample where we can see the problem (and where remove the dim override works as workaround).
And share your AutoCAD product version too, you can see it in ABOUT dialog.
Thank you in advance.
Sebastian
Message 11 of 11
hi CADffm , when the command line shows this the DimOverride is useful
Application reference error: ACAD, to AcDbLineTableRecord
