Unable to connect to license server
Users are unable to connect to license server.
are you going to give any more info than this?
12:15:02 (lmgrd) -----------------------------------------------
12:15:02 (lmgrd)   Please Note:
12:15:02 (lmgrd)
12:15:02 (lmgrd)   This log is intended for debug purposes only.
12:15:02 (lmgrd)   In order to capture accurate license
12:15:02 (lmgrd)   usage data into an organized repository,
12:15:02 (lmgrd)   please enable report logging. Use Flexera Software LLC's
12:15:02 (lmgrd)   software license administration  solution,
12:15:02 (lmgrd)   FlexNet Manager, to  readily gain visibility
12:15:02 (lmgrd)   into license usage data and to create
12:15:02 (lmgrd)   insightful reports on critical information like
12:15:02 (lmgrd)   license availability and usage. FlexNet Manager
12:15:02 (lmgrd)   can be fully automated to run these reports on
12:15:02 (lmgrd)   schedule and can be used to track license
12:15:02 (lmgrd)   servers and usage across a heterogeneous
12:15:02 (lmgrd)   network of servers including Windows NT, Linux
12:15:02 (lmgrd)   and UNIX. Contact Flexera Software LLC at
12:15:02 (lmgrd)   www.flexerasoftware.com for more details on how to
12:15:02 (lmgrd)   obtain an evaluation copy of FlexNet Manager
12:15:02 (lmgrd)   for your enterprise.
12:15:02 (lmgrd)
12:15:02 (lmgrd)
12:15:02 (lmgrd)
12:15:02 (lmgrd) pid 4664
12:15:02 (lmgrd) Detecting other license server manager (lmgrd) processes...
12:15:02 (lmgrd) Done rereading
12:15:02 (lmgrd) FlexNet Licensing (v11.11.0.0 build 106800 x64_n6) started on PWDC-OV (IBM PC) (12/11/2015)
12:15:02 (lmgrd) Copyright (c) 1988-2012 Flexera Software LLC. All Rights Reserved.
12:15:02 (lmgrd) World Wide Web:  http://www.flexerasoftware.com
12:15:02 (lmgrd) License file(s): C:\Program Files\Autodesk\Autodesk Network License Manager\Licenses\ACD2014enlicense.lic
12:15:02 (lmgrd) lmgrd tcp-port 27000
12:15:02 (lmgrd) Starting vendor daemons ...
12:15:02 (lmgrd) Starting vendor daemon at port 2080
12:15:02 (lmgrd) Using vendor daemon port 2080 specified in license file
12:15:02 (lmgrd) Started adskflex (pid 5508)
12:15:02 (adskflex) Unable to initialize access to trusted storage: 1
12:15:02 (adskflex) FlexNet Licensing version v11.11.0.0 build 106800 x64_n6
12:15:03 (adskflex) Server started on PWDC-OV for:
12:15:03 (adskflex) 64300ACD_F (consisting of:  86063ACD_2014_0F
12:15:03 (adskflex) 85871ACD_2013_0F 85730ACD_2012_0F 85536ACD_2011_0F)
12:15:03 (adskflex) Wrong hostid on SERVER line for license file:
12:15:03 (adskflex)  C:\Program Files\Autodesk\Autodesk Network License Manager\Licenses\ACD2014enlicense.lic
12:15:03 (adskflex) SERVER line says 0019b9ec07db, hostid is 0050569d340f
12:15:03 (adskflex) Invalid hostid on SERVER line
12:15:03 (adskflex) Disabling 1 license from feature 64300ACD_F(0EB1 CB8E 5160 92DA )
12:15:03 (adskflex) Disabling 1 license from feature 85536ACD_2011_0F(0EB1 CB8E 5160 92DA )
12:15:03 (adskflex) Disabling 1 license from feature 85730ACD_2012_0F(0EB1 CB8E 5160 92DA )
12:15:03 (adskflex) Disabling 1 license from feature 85871ACD_2013_0F(0EB1 CB8E 5160 92DA )
12:15:03 (adskflex) Disabling 1 license from feature 86063ACD_2014_0F(0EB1 CB8E 5160 92DA )
12:15:03 (adskflex) EXTERNAL FILTERS are OFF
12:15:03 (lmgrd) adskflex using TCP-port 2080
12:15:03 (adskflex) No valid hostids, exiting
12:15:03 (adskflex) EXITING DUE TO SIGNAL 25 Exit reason 2
12:15:03 (lmgrd) adskflex exited with status 25 (Invalid host)
12:15:03 (lmgrd) Please correct problem and restart daemons
Seems MAC address change but How do I change it in LMtools
DarrenP
you don't
you would need to generate a new license file
You can use the online method to activate your license here:
www.autodesk.com/register
DarrenP
