AutoCAD Forum
Unable to cast object of type '.....PreviewRuleProvider'
2 REPLIES 2
2406 Views, 2 Replies
environment = Win 8 pro x64, VS pro 2013 upd 4, .net fw 4.5.51641 and ACAD 2015 latest release.
Whenever I run a debug session in VS I see the error below, HOWEVER I do not see this error if I run ACAD normally (outside of VS)!
Can anyone explain why I am having this issue?
If you need more info please contact me.
NOTE: I looked at a previous post about this error which relates it to the video card.
If that is the case then way does it only happen in the debug environment of VS?
Application does not support just-in-time (JIT)
debugging. See the end of this message for details.
************** Exception Text **************
System.InvalidCastException: Unable to cast object of type 'Autodesk.AutoCAD.LivePreview.PreviewRuleProvider' to type 'Autodesk.AutoCAD.Internal.IPreviewContextProvider'.
   at Autodesk.AutoCAD.LivePreview.PreviewContextService.LoadContext()
   at Autodesk.AutoCAD.LivePreview.PreviewContextService.get_ContextProvider()
   at Autodesk.AutoCAD.LivePreview.PreviewContextManager.OnIdleInitialize(Object sender, EventArgs e)
   at System.EventHandler.Invoke(Object sender, EventArgs e)
   at Autodesk.AutoCAD.ApplicationServices.Core.Application.OnIdle()
************** Loaded Assemblies **************
mscorlib
    Assembly Version: 4.0.0.0
    Win32 Version: 4.0.30319.34014 built by: FX45W81RTMGDR
    CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll
Acdbmgd
    Assembly Version: 20.0.0.0
    Win32 Version: 20.0.210.0.0
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202015/AcdbMgd.DLL
adui20
    Assembly Version: 0.0.0.0
    Win32 Version: 20.0.51.0.0
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202015/adui20.DLL
AdUiPalettes
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202015/AdUiPalettes.DLL
WindowsBase
    Win32 Version: 4.0.30319.34004 built by: FX45W81RTMGDR
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/WindowsBase/v4.0_4.0.0.0__31bf3856ad364e35/WindowsBase.dll
System
    Win32 Version: 4.0.30319.34239 built by: FX452RTMGDR
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
PresentationFramework
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.dll
PresentationCore
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_64/PresentationCore/v4.0_4.0.0.0__31bf3856ad364e35/PresentationCore.dll
System.Xaml
    Win32 Version: 4.0.30319.33440 built by: FX45W81RTMREL
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xaml/v4.0_4.0.0.0__b77a5c561934e089/System.Xaml.dll
System.Configuration
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
    Win32 Version: 4.0.30319.34230 built by: FX452RTMGDR
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
AdApplicationFrame
    Win32 Version: 5.2.8.100
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202015/AdApplicationFrame.DLL
AdWindows
    Assembly Version: 5.2.10.200
    Win32 Version: 5.2.10.200
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202015/AdWindows.DLL
PresentationFramework.Aero2
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework.Aero2/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.Aero2.dll
System.Drawing
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
accoremgd
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202015/accoremgd.DLL
System.Core
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
Acmgd
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202015/Acmgd.DLL
AcWindows
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202015/AcWindows.DLL
AcCui
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202015/AcCui.DLL
AcWindows.resources
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202015/en-US/AcWindows.resources.DLL
PresentationFramework-SystemXml
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemXml/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemXml.dll
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework.Aero/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.Aero.dll
WindowsFormsIntegration
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/WindowsFormsIntegration/v4.0_4.0.0.0__31bf3856ad364e35/WindowsFormsIntegration.dll
Acmgd
    CodeBase: file:///C:/Users/Johan.EBCORP/Documents/Visual%20Studio%202013/CAD/Earthbound.ACAD.Plugin/Earthbound.ACAD.Plugin/bin/Debug/acmgd.dll
PresentationUI
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationUI/v4.0_4.0.0.0__31bf3856ad364e35/PresentationUI.dll
System.Xml.Linq
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml.Linq/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.Linq.dll
System.Windows.Forms
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
PresentationFramework-SystemXmlLinq
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemXmlLinq/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemXmlLinq.dll
accoremgd
    CodeBase: file:///C:/Users/Johan.EBCORP/Documents/Visual%20Studio%202013/CAD/Earthbound.ACAD.Plugin/Earthbound.ACAD.Plugin/bin/Debug/accoremgd.dll
FeaturedAppsPlugin
    Win32 Version: 20.0.46.0.0
    CodeBase: file:///C:/ProgramData/Autodesk/ApplicationPlugins/Autodesk%20FeaturedApps.bundle/Contents/Windows/2015/Win64/FeaturedAppsPlugin.dll
UIAutomationTypes
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/UIAutomationTypes/v4.0_4.0.0.0__31bf3856ad364e35/UIAutomationTypes.dll
PresentationFramework-SystemCore
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemCore/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemCore.dll
Anonymously Hosted DynamicMethods Assembly
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_64/mscorlib/v4.0_4.0.0.0__b77a5c561934e089/mscorlib.dll
ContextualTabSelectorRules
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202015/AcWindows.dll
Microsoft.Expression.Interactions
    Win32 Version: 2.0.20520.0
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202015/Microsoft.Expression.Interactions.DLL
AcWindows
    CodeBase: file:///C:/Users/Johan.EBCORP/Documents/Visual%20Studio%202013/CAD/Earthbound.ACAD.Plugin/Earthbound.ACAD.Plugin/bin/Debug/AcWindows.dll
AcLivePreviewContext
UIAutomationProvider
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/UIAutomationProvider/v4.0_4.0.0.0__31bf3856ad364e35/UIAutomationProvider.dll
Accessibility
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
************** JIT Debugging **************
Application does not support Windows Forms just-in-time (JIT)
debugging. Contact the application author for more
information.
2 REPLIES 2
Keith.Brown
I know this is an old post but it happened to me by accident.   I had the copy local = true for the autocad dll's and it was causing the issue.  Setting the working directory on the debug page to C:\Program Files\Autodesk\AutoCAD 2015 fixed it for me.  Alternatively you can do copy local = false.
in reply to: Keith.Brown
Can you explain this to me like I'm 10 years old?
I got this same error when testing out the ability to "check out" a DWG file from ProjectWise to edit it. As soon as the AutoCAD drawing opened, I received this error. I clicked continue, but it crashed later from a fatal error when trying to modify a table within the drawing.
AutoCAD Inside the Factory
