UCS and offset issue
pbejse
Mentor Mentor
Message 1 of 8
pbejse
Look at the UCS icon's behavior? Has that got anything to do with why the user cannot offset the lwpolylines?
Command: OFFSET
Specify through point or [Exit/Multiple/Undo] <Exit>: .5
Cannot offset that object.
Select object to offset or [Exit/Undo] <Exit>
What is going on here?
I know the solution is to move everything near 0,0,0, but that does not explain why this drawing is behaving the way it does.
Replies (7)
Message 2 of 8
Patchy
It does that if it's a 3dpoly and offset, it will not let you.
Message 3 of 8
Alfred.NESWADBA
I guess your coordinates are much to high to work correct with double precision (or too small).
Either use command _ID or turn on coordinates in the statusbar to check this ... or upload the dwg-file.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 4 of 8
pbejse
@Alfred.NESWADBA
- alfred -
 I meant to do that, but i completely forgot to include the file. my bad..
Message 5 of 8
Alfred.NESWADBA
type (as mentioned before) command _ID, then pick a point within your scene and look to that coordinates:
Much to high for double precision calculation with current CPU's.
- alfred -
Alfred NESWADBA
Message 6 of 8
Alfred.NESWADBA
another screenshot:
How did you get the objects to these coords?
Move them more close to 0,0,0 and all will be ok.
- alfred -
Alfred NESWADBA
Message 7 of 8
pbejse
- alfred -
That explains it, Thank you
Any suggestions besides moving the while thing near 0,0,0 coordinates?
Message 8 of 8
Alfred.NESWADBA
No, AutoCAD (and other vector based systems) don't work well at that high coordinates.
And I don't know any need to work at such high coordinates.
- alfred -
Alfred NESWADBA
