Is it possible to turn off a layer in one viewport only, while in the model?
All the instructions I've found for turning off a layer in one viewport refer to layouts (modelspace/paperspace). I want to be able to do it in the model with multiple viewports.
Thanks.
Solved by imadHabash. Go to Solution.
It's NOT applicable .
separate them in different layers so you can turn it off? thanks
Viewports in the model are all viewing the same model/Layers so I don't think it is possible to have the same entity (in this case a points cloud) on two different layers at the same time. I think this is a similar same reason as to why imadHabash said that my request is NOT applicable.
Thanks.
