Turn off context sensitive menu in Ribbon
ThomasAbsotech
ThomasAbsotech
When I select a object in model space the ribbon menu changes from "Home" to what AutoCAD thinks I want. This is slowing my down my productivity, as I need the ribbon to stay on the "Home" menu.
I understand there was a variable that solved this and was dissolved in 2015 for some odd reason.
Mike
vinodkl
Hi @ThomasAbsotech
See if this helps: How to disable contextual ribbon tabs in AutoCAD 2015 and later
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
