- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I've been trying to overlay a drawing with another drawing to compare them and I've been using the insert command.
I can't seem to select a drawing though because when I click on the drop down menu to select a file the menu does not drop down and the file location goes blank.
I am able to select a drawing use the options on the left hand side of the file select window, however when I select a file and hit ok to insert it I get the message, "file name must contain at least one character". If I then exit the insert command window, I am not able to do anything in AutoCAD except move my mouse.
So it seems like the insert command has somehow be corrupted as any time I use it AutoCAD crashes and I have to restart it.
I have tried restarting AutoCAD and rebooting my PC, but neither of those have solved this issue. My next move would be to re-install AutoCAD, but I don't really want to have to do that.
If anyone has any suggestions on how to solve this, it'd be much appreciated.
Thank you
