Trying to explode everything disappears
Message 1 of 12
I am trying to do some setting out but when I explode the drawing everything disappears.
I have attached my drawing. please help
thanks
Replies (11)
Message 2 of 12
imadHabash
i don't know how did you prepare this drawing or from where you get it !! BUT what i know is that this drawing needs a lot of works .
  • you have a lot of CAD items fly in the model space. try to Zoom (Extents) .
  • try to audit and purge(regapps) your drawing after evrey explode command to reduce the file size.
  • i explode the red streets and nothing weird happened (as much as i know) !!
please Notice the CAD attachment file down there for your action.... and if you want more help please put a rectangle for what certain drawing that you care about so that we know what to ignore. hope it's help.
Imad Habash
Message 3 of 12
user181
I tried the explode command and everything disappeared like you said and command line said invalid. I used the BURST command and it exploded normally. I also tried the XPLODE command and then chose the option Explode on the command line and it exploded normally as well.
Message 4 of 12
thank you for the file
the file you sent me works perfectly fine but when I explode the original file myself everything disappears.
i have attached a new file and i have a put a revcloud around the area where i explode everything disappears.
Message 5 of 12
I tried burst command it says invalid. dont know why
thanks
Message 6 of 12
imadHabash
please confirm that if use XPLODE command for this clouded area it's disappeared or what ? because it's work fine with me.
Imad Habash
Message 7 of 12
pendean
Community Legend
Community Legend
Friend, everyone is asking you to use the command XPLODE, it has no E at the beginning, it's not misspelled, it's different from EXPLODE which has an E on both ends.
Your file contains CIVIL3D content and probably why you cannot explode much.
Your file is also problematic to say the least
See attached, I used XPLODE command to get you want you wanted and I got rid of the CIVIL3D content as well.
Message 8 of 12
My friend I used both explode and xplode in both case it is the same
thanks
Message 9 of 12
i did use explode and xplode in both case everything disappeared.
I used burst command it says invalid
Maybe I have some problem with my computer or autocad then. I restarted my computer a few times but still I have same problem. anyway I will use your file loool.
If you can tell me how you used xplode command?
I wrote xplode in command line then chose all and then just pressed enter to chose everything by layer. basically wrote xplode in command line chose the object and chose all and then enter and enter at the end everything disappeared.
thanks
Message 10 of 12
pendean
Community Legend
Community Legend
What version of AutoCAD are you using? As you can see from the repost of your DWG that I provided, we all can do what you want.
Message 11 of 12
I am using autocad 2017 full version.
Message 12 of 12
pendean
Community Legend
Community Legend
Same here, works fine.
Did you access the file I posted? Isn't that what you want?
