AutoCAD Forum
Trying to create a 3D flower with each petal layer at different angles
3 REPLIES 3
2826 Views, 3 Replies
I am a new user (AutoCAD 2020) and am trying to make a flower for 3D printing. I was able to add different layers of the petals but it does not make a difference in the elevation of the petals, having essentially no effect. Is there a way to insert new layers at different angles? Or how can I make the petals curve upwards at an angle, away from the base.
Please see the attached pictures for reference. I am trying to made a simple model of the flower in the picture. Thank you!Image result for lotus flowerautocadqsnip.PNGautocadqsnip2.PNG
3 REPLIES 3
Erense
You haven't chosen the simplest to start with.
First you would have to start with creating crosssections of a petal. Every crossection is a closed polyline with different shape.:
Then you create a loft over every cross-section:
Then you start placing the petals like you want them. You might even scale them to create different size petals.
Create a 'solid' heart and base all petals are connected to and join them into 1 solid.
( have not gone that far 😉 )
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Kind regards,
Edwin Rense
Cadac Group AEC BV
Supporting Consultant AEC
Cadac Group .
in reply to: Erense
Hi Edwin,
Thank you for your response. I was wondering if you could please elaborate on how to "create a solid heart and base all petals are connected to".
Sofia
Erense
Creating the base and heart are for 3D printing but are 'needed' dependent on how your petals are put together.
If there is space between the petals and you might print that part, the flower may not be connected and fall in pieces.
So if needed you should create a solid part to keep all subcomponents connected.
Kind regards,
Edwin Rense
Cadac Group AEC BV
Cadac Group .
AutoCAD Inside the Factory
