Trouble with shift key for ortho mode
Message 1 of 17
Hi all!
I have  trouble, with my shift key. I've just get a new machine and when i installed autocad 2013 the shift key shouldn't want to switch the ortho mode. In the temporary shrt keys there is the description, but didn't work. On my previous machine it worked perfectly. I've tried lot of solution, but they didn't work. Does anyone know the solution?
Máté
Replies (16)
Message 2 of 17
pendean
Community Legend
Community Legend
What is your .TEMPOVERRIDES variable set to? Usage explained in HELP.
Message 3 of 17
I've checked my TEMPOVERRIDES andi it says my value 1. I tried it value 0, but didn't work. I saw in it the Help and first i tried this.
Message 4 of 17
pendean
Community Legend
Community Legend
There is a slight time-lag for some users after they press down SHIFT-key, could that be it?
What's different about the new PC from the old one?
Message 5 of 17
My previous laptop is an MSI cx-623 with windows 7. The new one is better in performance, but it runs with windows 8.1, because windows 7 is not supported very well, and drivers too. It is a levono z50-70. All of hem have intel chipset, and nvidia gpu, bu it is better of course. I don't understand this slight time-lag, what it means? My first idea is that, to wait a ittle when i hold shif key, but nothng happend.
Message 6 of 17
pendean
Community Legend
Community Legend
R2013 is not supported in Win8.1, but is supported in Win7.
Does your new laptop map SHIFT o do something else? or you must press a hotkey to activate it?
Or is there a key logger running in the background as a system service? Or a Norton product like Constant Guard installed?
Message 7 of 17
My shift is direcly working, not needed t press ot keys. I haven't got a key logger, and norton products. About map shift I didn't understand what it means. Sorry about that...
Message 8 of 17
pendean
Community Legend
Community Legend
Walk me through a process where it fails so that I can replicate: do it on screen at your end first to ensure it fails. List every command, click, button hold, how long you hold anything down for etc.
Message 9 of 17
I've reseted autocad 2013 first, if i made some mistakes.
Launch autocad 2013
Type: TEMPOVERRIDES -> Enter -> Command line shows: Enter new value for Tempoverride <1> -> Type 1 ->enter -> try a line command, ->pick to a random point, then move mouse while i hold shift key -> line didn’t go to orto mode.
Other trying: Type: cui -> enter –>new tab showing: Costumize user interface. Serch keybord shortcuts, click on it. -> search Toggles Orthogonal Mode, see keys SHIFT, macro 1: ^P'_.orthomode $M=$(if,$(and,$(getvar,orthomode),1),$(-,$(getvar,orthomode),1),$(+,$(getvar,orthomode),1)) -> Try to redefine to shift -> Double click ont he column Keys and press delete, then SHIFT. It shows key is shift. -> Press OK. -> try line to get ortho mode the same way like previous, nothing happening.
Also seeing F8 is the key of Toggles Orthogonal Mode, and it is  working, but shift is not.
Also see Ctrl + L is ortho mode on/off and it is working...
Message 10 of 17
pendean
Community Legend
Community Legend
Why are you redefining the shift key temp override in CUI? OOTB installation here, no migration from an older AutoCAD. Were you reading this post?http://forums.autodesk.com/t5/autocad-2010-2011-2012/shift-key-and-ortho-lock/td-p/2724361
Are you all by chance running an Enterprise CUI?
I can't replicate the issue in Win7: I don't have Win8.1 to test either.
Message 11 of 17
nestly2
Does Shift key work for other AutoCAD specific functions?
ie SHIFT within TRIM should switch to EXTEND, and SHIFT within EXTEND should switch to TRIM.
also, SHIFT within FILLET command should fillet with a zero radius regardless of the actual radius specified.
Message 12 of 17
Ok, i reset Autocad again. I've checked this post before, but it still not working, nothing happend. I did it again, but the solution ended in the same way, nothing happend. I don't know what cause this, I can't belive it because of Windows 8.1... I tr to reinstall autocad...
And other orders Shift is perefectly working, like Trim and Extend...
Message 13 of 17
I reinstalled autocad, but all the thing what you gave me not working unfortunatelly. I haven't got an idea what will be the problem, maybe windows 8.1 or my hardware...
Message 14 of 17
I get a new autocad 2015, and thought it solves the problem, but it is the same. I tried all the advices and it won't worked. Then I tried to override the override key to SHIFT+Í (i am hungarian, and I have a hungarian keyboard and autocad) and it is working. I don't know how, but it is working. Also if someone knows what is the main problem please write to me, or anythig, that works.
Message 15 of 17
GrantsPirate
drwuki - when you go into the CUI, Keyboard Shortcuts, be sure to go into the Temporary Override Keys and varify that Toggles Orthogonal Mode is there and is set to Shift.  Also, don't type SHIFT, pick on the area to define the key, then pick on the ..., finally place your cursor there and press the Shift key.
Also, make sure the Caps Lock is off while doing the above.
GrantsPirate
Piping and Mech. Designer
EXPERT ELITE MEMBER
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
Message 16 of 17
I have the same problem over the temp ortho mode using shift key, I'm running AutoCAD 2016 x64 on windows 10, i checked the tempoverrides its set to 1 and i also tried changing the macro setting for the shift key but still didn't work. I attached my current setting for keyboard shortcuts. i changed all the 1's in the down key to 0's in the up key, still didn't work, i don't know if this is the right macro for 2016 as i found this solution in an AutoCAD 2010/11/12 board discussion.
Message 17 of 17
I have the same working environment as you, and the same settings. Nothing seems to be working.
We need AutoDesk to come to the rescue
