When I try to install Service Pack 2, I get a Net Framework error:
This is a bit odd because I have 4.7 installed which is newer.
Any ideas how to get past this?
thanks
Solved by dmfrazier. Go to Solution.
With some older version AutoCADs it is actually necessary to "roll back" your .Net version to the one it expects. (IOW, uninstall the newer version and re-install the older.) I know this was the case when installing the 2015/16 product on some machines here. It seems ridiculous to have to do this, but it does work. You can use Windows Update to re-update .Net after the install.
Sebastian
