Trouble using Button Editor within CUI - Bug report & Work around (2015)
- Mute
- Permalink
- Report
I'm a non Ribbon Bar user, completely aligned with the old .MNU now .CUI icon menu system user/customizer. I found a need to add a couple of new command buttons to my toolbars and ran into a rather annoying bug with the interface. I was able to find work arounds so this is post is to make those aware and provide a means to complete the task until the bug gets fixed.
Upon opening the Button editor within the CUI window, I began having use/access problems Once I edited one of the pixel's with a new color and let go of the mouse button, my mouse could no longer access the AutoCAD window. I am using dual monitors on my setup with AutoCAD on monitor #2. What I found was that this window does not work correctly unless the editor is located on the Primary Monitor. I did have some success using ALT+TAB to scroll through open windows, return to the AutoCAD window, and then was able to drag this Button Editor dialog box to the primary screen, and was then able to use this editor normally. While the cursor was behaving in this manner, I was not able to get my mouse cursor to move onto my secondary screen at all. I don't know how far back this issue goes, but if you find yourself looking for a fix, this work around should let you complete your desired task.
