Trimming Hatch with Block Entity creates duplicate block entities
07:22 PM
Autocad has started duplicating block components following a hatch trim using a block as a trimming edge.
Essentially I have a window elevation created as a block.
This block is then placed on a wall with hatching representing cladding.
When I activate the trim command & select the outer linework & trim out the hatch a significant number (hundreds) of additional individual lines are created & stacked on top of each other. If you delete the hatch, place the window & redo the hatch there's no issue.
Current service pack has been installed.
Any help greatly appreciated.
