Trim Command isnt working properly
hamoodpg
hamoodpg
Hello I'm an interior design student and I'm working in details so I always use the command trim but suddenly I faced a problem which it seems like the command is cutting out the line not trimming it so if I want to trim an intersectional line it actually cuts it through parts I tried it in different plans but it still I'm facing the same issue.
user181
Hi @hamoodpg   After starting the trim command you can see options on the command line. Select the Edge option and make sure it set to no extend.
hamoodpg
THANK YOU
user181
You're welcome
allurecustomhomes
THANKS THAT HELPED ME ALSO!
