Tricky Hatch Pattern - Help Needed
bwhisenhunt
bwhisenhunt
I have a hatch pattern I can't figure out.   It should be simple but I'm stumped on what I have wrong.
*Wallcovering_WC72,
0,0,0,0,4
45,0,0,5.65625,0,8,4.5
315,4,4.5,-5.65625,0,8,4.5
It SHOULD look like this:
Kent1Cooper
It can be confusing to get things right, because while the origin point, even for a line set at an angle, is relative to the origin in unrotated  X & Y distances, the offset values are in relation to the rotated  direction of the line set.  Your first line looks right.  Try this for the second and third lines [untested]:
45, 0,0, 5.656854,5.656854, 5.656854,-5.656854
315, 0,0, 5.656854,5.656854, 5.656854,-5.656854
EDIT:  Fixed that last line -- either  315, 0,0,  or  135, 4,4,
Kent Cooper, AIA
bwhisenhunt
315, 0,0 fixed it!   Thank you!   I have a definite mental block when it comes to hatch patterns.
