Tree canopy help?
Tree canopy help?
Message 1 of 9
Tree canopy help?
Hi everyone, right I run AutoCAD 2016 LT, I'm trying to plot tree canopies using circles. This is fine until I come across a tree with an unbalanced crown. I can't figure out how to plot a circle with 4 different radius? I know it is possible as I've seen drawing before that can achieve this. Any help would be really appreciated, also I'm not an advanced user, in fact I'm a bit of a novice.
Thanks in advance
Tom
Replies (8)
Message 2 of 9
john.vellek
HI totterfield and welcome to the Forums!
Can you attach a sketch or picture of what you are trying to do? I imagine from your description that you want a connected series of arcs to represent the tree canopy.
I am happy to help you with this if you can clarify your exact question.
John Vellek
Message 3 of 9
rkmcswain
More like #1 or like #2 ?
Message 4 of 9
JasonArtley
A "passible" tree canopy can be made by using the REVCLOUD command. Just make sure the end result looks more like a tree than a revision cloud!
Message 5 of 9
A bit like number #1, sorry I'm on my phone cannot really post an image,
http://www.pjcconsultancy.com/arboriculture/tree-constraint-plans/
The picture in the background is kind of what after. Circle with 4 radius for each easting . I do use reccloid to make them look a bit more interesting.
I've usually got lots of these canopies to plot, so making arks would be a very long ordeal
Message 6 of 9
Try giving SPLINE a shot.
Message 7 of 9
john.vellek
Hi @Anonymous
I took three circles and overlapped them a bit. I then trimmed out the interior portions, converted the remaining arcs into a polyline.
Now, I can grab a vertex (or even insert additional ones) and stretch the shapes in a variety of ways. Perhaps I need to do this with four to make it better. I was wondering if something like this would work for your needs.
Please hit the Accept as Solution button if my post fully solves your issue or answers your question.
John Vellek
Message 8 of 9
john.vellek
Hi totterfield,
I am checking back to see if my post or others helped you with your problem. Please add a post with your results so other Forum users can benefit.
Please hit the Accept as Solution button if a post or posts fully solved your issue or answered your question.
John Vellek
Message 9 of 9
Thanks for everyone's help, I found spline to be the best solution
