Transfering all toolbars to another computer
Message 1 of 12
Hello everyone,
I have a question about transferring toolbars.
As you can see in the pic.
https://www.dropbox.com/s/2mb98geb9um21tp/2017-04-24_15-08-14.jpg?dl=0
I use the classic autocad toolbars , and I added more addons from autodesk , and I created customs toolbars that in them I load my favorite lisp in icons.
I want to migrate all these toolbars in the exact position to another computer , or another autocad.
Using the migrate setting of autocad in the start menu , doesn't work so good.
Is there step by step manual that shows how to transfer all my settings ( especially my toolbars in the current position).
Thank you
Eyal
Replies (11)
Message 2 of 12
All customizations are saved within your main customization (CUIx) file.
Location shown below.
Message 3 of 12
john.vellek
Hi @Anonymous,
I suggest that you keep all of your toolbars and other menu customizations in a partial menu. If you would like to send me your current menu(s) I would be happy to outline steps to put your customizations into a new file.
Here is an article that helps detail transferring toolbars that you might find useful.
John Vellek
Message 4 of 12
Hi John,
I sent you my customiztion toolbars ,
Please tell me how can I save them.
As I mentioned I have edited my "acad2016doc.lsp" ,and added the lines:
(load "LINE_DIV")
(load "ObjectBreakV1-0")
(load "combinetext")
(load "3P-RecV1-0")
(load "IncArrayV1-8")
(load "BoxTextV1-2")
(load "AlignTextToCurveV1-2")
(load "clm")
for loading these lisps in autocad at startup, also I put these lisps at the same folder as "acad2016doc.lsp".
How can I migrate all my settings including this.
Thank you.
Eyal
Message 5 of 12
jayhar
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Transf...
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly.
Message 6 of 12
john.vellek
Hi @Anonymous,
When I review some of the commands I see that they are AEC ones. Are you working with AutoCAD Architecture and not plain AutoCAD?
I imagine that the icon images are stored in a DLL that is not part of plain AutoCAD.
So, I think from just glancing at this, you are having issues with paths to your LISP routines and to your images.
Can you give me some more details?
John Vellek
Message 7 of 12
I use regular autocad 2016 , and transferring my workspace and toolbars to another regular autocad ( sometimes in other up versions).
I store my icon images in a folder in autocad. If you think that I should store my pictures in a specific folder I'll do so.
I just want all my settings to go with me.
Yesterday I have tried once more to migrate my settings to another computer and some of my toolbars were in a question marks , and some added commands didn't show , and the addons didn't appear.
Thank you
Eyal
Message 8 of 12
john.vellek
Hi @Anonymous,
Is it possible to zip up your image files for me so I can see if they load properly when I select your custom workspace?
John Vellek
Message 9 of 12
pendean
Community Legend
Community Legend
CUI command in your newer setup has a transfer tab, all you need is the copy of your old CUIx file to reference content over. Drag and Drop.
Just make sure you transfer and place your custom icons in the new setup's search paths first. ?-marks means they were not found.
Message 10 of 12
Emmsleys
Checking in on your thread, it appears that several folks have tried to help on this issue. Were you able to find a solution? Or a workaround?
Did any of the posts in the thread help with your issue?
Please post back in the thread if you are still having an issue with AutoCAD or Select Accept as Solution for the post’s that helped.
Thanks for your time.
Sarah Emmsley
Technical Support Specialist
Message 11 of 12
Hello Emmsley , and guys
So far, I didn't succeed with saving my settings.
I tried to save the cui file and transfer it to another computer but some of the toolbars are not in the correct position. also in my custom toolbars ,some of the icons are not visible.
this weekend I'm tring to do another check and I'll inform you.
Thank you,
Eyal
Message 12 of 12
john.vellek
HI @Anonymous,
You are welcome to zip up your image files so I can try to get them to work on my end properly.
John Vellek
