Transfer tags to values
Hi Mates..
Im a Gis specialist and facing an issue with cad to gis conversion for this particular files..
This cad file has layer names as " DI line , DI text and old Line" ..
I have exported this data to GIS succesfully but i have been failing to get the exact dimensions of the lines attach to each..
I came to transfer tag to values is the solution , any one can share steps or process to perform it
Please find the attached drawing
Any ideas
Alfred.NESWADBA
Do you have Map3D or Civil3D ... or how did you export your data to a GIS system?
Which GIS-system are you using?
Layer "DI line" does not exist, layer "DI-LINE" is empty, only "D.I LINE" has polylines with widths
Layer "old Line" does not exist
Which objects exactly are not meant?
What are the exact dimensions? Are you referring the pipe diameters or anything more?
As far as I can see the diameter can be exported by evaluating the polyline-width property, no need to read any text.
Sorry, I don't understand this "transfer tag to values", can you elaborate this please?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Thanks for your reply..
I have opened the drawing into ArcGis software and i have selected only the pipeline and then exported the desired layer which is D.I Line as shown in the screenshot..
I need this layer in shape file and succesfully created but failing to get pipe diameters..
I came to know that before GIs step , I need to Convert tag to text then process in GIS for this type of drawing and only cad specialist can help in this case
Short demo by someone on coversion in gis
https://www.youtube.com/watch?v=uze05gsBwmU
Alfred.NESWADBA
If you want to learn the handling of importing a CAD-file in ArcGIS you'll need to ask in the ArcGIS-forum.
The most easy way would be if you have access to AutoCAD Map 3D or Autodesk Civil 3D ... do you have access to any of that programs? That would give you the option to export to SHP and export the polyline-width (replacement for the pipe diameter) too (and assigning the geographic coordinate system to the geometry).
Sorry that I don't know what is "tag" for you.
- alfred -
Alfred NESWADBA
Alfred.NESWADBA
maybe that helps: I have attached an exported ZIP-file from the polylines with their polyline-global width, which I guess is the diameter in unit Meter.
However, please take care, the one who created that data, broke the lines for labeling (which is technically bad), so you need to connect these lines manually:
- alfred -
Alfred NESWADBA
Could u please mention the process steps
We have civil 3D also
Alfred.NESWADBA
Is the SHP I have attached to my previous message the result you are looking for?
Just to prevent to create a video that does not show what you need.
The command I used was _MAPEXPORT, to create a SHP, type lines, with an attribute WIDTH based on the polyline-globalwidth. Before that I selected all polylines on that one line-layer that are red (the outline for the labels interrupting the line) and moved them to a different layer to prevent that they are exported as pipes.
- alfred -
Alfred NESWADBA
