AutoCAD Forum
ToolsPalette Issues
5 REPLIES 5
374 Views, 5 Replies
ToolsPalette Issues
Hello, I recently had a tools palette that I created and imported
into AutoCAD. However now when I try to use the blocks it says "it
can't find the files" I've tried relinking the files and even moving
them to a new location and relinking them but nothing seems to work.
Hopefully, you can help me out or point me the direction of a forum
that will help me. Cheers, Kelsey
ToolsPalette Issues
5 REPLIES 5
pendean
pendean
Community Legend
Community Legend
The error message usually means the source file for the block is not accessible: where is that?
Alfred.NESWADBA
Alfred.NESWADBA
>> when I try to use the blocks it says "it can't find the files"
The palette just knows where the block is stored, if that drawing is not found then you get that message.
So if you have created the palette on one system from a drawing that is stored in that system on drive C: you have to copy this file(s) to the other workstation with the same path.
For future: whenever you create a palette, make sure that the drawing with the blocks (you are using in the palette) is first saved into a network folder which every person can use/has access to that file(s).
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
- alfred -
Alfred NESWADBA
in reply to: Alfred.NESWADBA
I've tried copying over the drawing as well but it still isn't working...
Kelsey Shaw
Environmental Engineering BASc in Progress
University of Waterloo
kelsey.alexandra.shaw@gmail.com
705-323-0031
Kelsey Shaw
705-323-0031
pendean
pendean
Community Legend
Community Legend
>>....I've tried copying over the drawing as well but it still isn't working......<<<
Explain: your abbreviated response is not adding much to the discussion.
in reply to: pendean
I mean I moved the drawing with the original blocks for the tools palette along with the tools palette files themselves to a general location but when I import them in CAD they still won't work. It still says the location cannot be found. (see attached screenshot).
AutoCAD Inside the Factory
