Hi Dean, thank yo for responding. I will look at some of the settings in the article you sent.
I guess since I was self taught and have worked with AutoCAD since release 8, I have always used the toolbars. I did not care to take the time to try and customize the ribbons because the toolbars were not broken. 🙂 why fix something that is not broken.
If you eat with using your fork in your left hand why would you change to your right hand if the left hand is still intact? And The way my mind works having more real estate to work with just means I have to mow more. Some just see it from another perspective I guess.
At one time I was very knowledgeable with AutoCAD. Before it was part of AutoCAD I wrote my own COPY/ROTATE lisp routine. Over the years job promotions did not require me to use AutoCAD as much. Especially around the time they went to Ribbons. I did not care for it as it appears some of the Icons changed or seemed to change.
Sometimes that old road you go down everyday is a bit comforting in that it is something you know will not change, and you can almost drive it with your eyes closed. I understand someone may find a way to build a better mouse trap, But quite frankly I like the old snap kind. you can hear it when it goes off and it is 97% reliable. It is OK for someone to use the new mouse trap, but please do not take my old ones away.
Thank you again for your help and expertise. It is very welcomed and inspiring, at least by this old fart that refuses to change to Ribbons. 🙂 Sorry for all the old cliché's
