Toolbars in Acad 19
Toolbars in Acad 19
Message 1 of 10
Toolbars in Acad 19
I use toolbars a lot (not a ribbon fan) installed 19, no toolbars appear.
Replies (9)
Message 2 of 10
pendean
Community Legend
Community Legend
How far back a version did you upgrade from? The workaround has been the same for a few versions now...
ReCreate the "Classic" Workspace with all the toolbars and pulldown menus from old (with no Ribbon) in about one minute:
MENUBAR command, turn it on = 1 (4 seconds)
Go to Tools > toolbars > acad > layers (5 seconds)
hoover over layers toolbar > right click > properties (3 seconds)
hoover over any toolbar > right click > standard (3 seconds)
hoover over any toolbar > right click > styles (3 seconds)
hoover over any toolbar > right click > workspaces (3 seconds)
RIBBONCLOSE command (3 seconds)
arrange toolbars as you desire (20 seconds)
WORKSPACE command, SAVEAS option, CLASSIC will be the new name you type (5 seconds)
Message 3 of 10
john.vellek
HI @Anonymous,
Which toolbars are you looking for in AutoCAD 2019? Are these some that you migrated from a prior release?  Please give me a bit more detail so I can offer some suggestions.
John Vellek
Message 4 of 10
JamesMaeding
oh geeze, all these years I did not notice tool pulldown had toolbars in it.
Renting autocad really is worth double now 🙂
internal protected virtual unsafe Human() : mostlyHarmless
I'm just here for the Shelties
Message 5 of 10
these toolbars are from years of acquiring from different coworkers.
usually once I load the my custom menu, they would pop up with the newly loaded menu.  Not doing it with '19.  Menus and pull downs are appearing and working as usual.
also (not to over burden you), Acad 19 will not save a drawing.  It started out giving me the error saying  that I was trying to save a read only file within my dwg.  I opened a new dwg and put only the following text..."this is a test".  Nothing else is in the drawing.  Now I am getting the message...."One or more objects in this drawing cannot be saved to the specified format.  The operation was not completed and no file was created.
Message 6 of 10
TheCADnoob
if you right click and run as administrator does that solve any of the problems?
CADnoob
Message 7 of 10
not sure what to "right click" on???
Message 8 of 10
john.vellek
HI @Anonymous,
Is it possible to share your toolbars on a post so I can see why they might not be loading?  Have you tried using the -Toolbars command at the command line?
With regards to the Saving issue, where are you saving your files? are you saving to a local drive, network, cloud location? Or are you opening the file that is contained as an attachment in an email?  The operating system controls file locking and permissions.
What file format do you have set as the default?  When you create or open (and save) a drawing in AutoCAD 2019, it will have newer versions of AEC content placed in it. You can use -EXPORTTOAUTOCAD to save it down to a prior version with only AutoCAD content.
John Vellek
Message 9 of 10
JamesMaeding
for the menus, be sure to delete the .mnr files before starting acad, they are right next to the .cuix.
Do you see the toolbars in the CUI tree though? If you can load the menu but not see them, you have an interesting problem. In general though, cui's from previous releases load into new ones.
Be sure if you have images or a .dll for them its present in support paths.
BTW, why anyone would store custom menus in cui or cuix files is beyond me.
THe original .mnu format is so much better as its text file based, not CUI, and just always works.
Once you go cui, you are stuck with any mistakes adesk makes in reading or using them, like you might be right now.
Message 10 of 10
PhilvK
I have some commands on toolbars in my old version of Autocad 2010 that I would like to add to the Acad 2019 ribbon or tool palettes, whichever is more appropriate. I’ve exported my Acad 2010 settings using Migrate: will importing those settings into Acad 2019 mess things up?
I would really just like to find a way to add a few old tool buttons to my new 2019 palettes but have no clue where to start, and have never really understood the Migration process, nor been successful in getting it to work.
