Toolbar Button Fails to Invoke Script
Message 1 of 23
(repeated because I lost it once)
I created a toolbar. I am trying to have it invoke a script. I click on the toolbar, and it fails to bring up the script. Everything looks right to me, but it doesn't call the script. Can someone guide me to how I find out what I did wrong?
Replies (22)
Message 21 of 23
Alfred.NESWADBA
>> The command line reports absolutely nothing.
Can you post a screenshot of the CUI showing how the button is configured.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 22 of 23
Can we schedule some way that someone from Autodesk, such as our representative to connect via Remote Desktop, such as possibly with "TeamViewer" which I have on my system, in order to diagnose this bug?
Message 23 of 23
john.vellek
HI @Anonymous,
As this is the Community Forums, a remote session is not part of the normal process for support through this means.  You are welcome however, to schedule a call to request direct support from here.
If you would like to continue working through the forum, please attach a screenshot of how you have customized the button. I also suspect your path might be at issue. It needs to be included in both  the Support path as well as the Trusted path.
If you press F2 at the end of trying to run your lisp routine it will show the text window which should tell you the results of what happened when you pushed the button.
Please select the Accept as Solution button if my post fully solves your issue or answers your question.
John Vellek
