Toolbar Button Fails to Invoke Script
Message 1 of 23
(repeated because I lost it once)
I created a toolbar. I am trying to have it invoke a script. I click on the toolbar, and it fails to bring up the script. Everything looks right to me, but it doesn't call the script. Can someone guide me to how I find out what I did wrong?
Replies (22)
Message 2 of 23
john.vellek
Hi @Anonymous,
Can you attach the command that you are trying to run?
I look forward to helping you.
John Vellek
Message 3 of 23
TheCADnoob
did you check in the CUI to make sure the script as it should be?
CADnoob
Message 4 of 23
Yes. I can't detect anything all by myself that is standing out as being
incorrect from
what I know.
I must be missing a detail that I don't understand.
Message 5 of 23
Alfred.NESWADBA
as mentioned: please show the syntax of the command you use behind your cui-button.
Another question: what happens when you start command _SCRIPT with your file manually?
At least: look to the security options (like trusted paths in the _OPTIONS dialog as well as the setting of the sysvar SECURELOAD, maybe the script file is stored at a path not allowed to run an app from.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 6 of 23
This is the code behind the button:
^C^C(load "c:/structural/system/lsp/shlm.lsp");shlm;
When I use (load "c:/structural/system/lsp/shlm.lsp");
It brings it up successfully,
and when I execute it, it starts the routine, (although it's not really functional at this state of development).
I need to research how to do what you are saying about the _OPTIONS dialog and SECURELOAD, (I have never heard of that issue before).
I am using random web articles to guide me, because even though I have a whole collection of Autocad books, there is no "system" to their organization to guide me.
Message 7 of 23
john.vellek
HI @Anonymous
When I put this ^C^C^p(load "c:/structural/system/lsp/shlm.lsp");shlm into the command line for a menu button it looks like it is working.
TO add the Folder to the Trusted Locations, simply type Options and then select the File tab. You can then add your folder to the list of Trusted Locations.
Please select the Accept as Solution button if my post fully solves your issue or answers your question.
John Vellek
Message 8 of 23
john.vellek
Hi @Anonymous,
I am checking back to see if my post helped you with your problem. Please add a post with your results so other Forum users can benefit.
Please hit the Accept as Solution button if my post fully solves your issue or answers your question.
John Vellek
Message 9 of 23
The problem still exists on my system. What you told me to do doesn't work to solve it.
I am completely lost as to what I should try next.
Message 10 of 23
john.vellek
Hi @Anonymous,
Please attach your LISP routine and I will duplicate your setup to see what might be the problem.
John Vellek
Message 11 of 23
I personally like to think that the process of solving this issue is a methodical/analytical process.
Can you describe to me what it is that I have to do in the case of this bug to figure out where the issue is?
(Like with a sequence of steps)?
Message 12 of 23
john.vellek
HI @Anonymous,
This is what I would do on my own system.
  • Create a folder for my custom LISP routines. Name it something like MYLSIP
  • Open AutoCAD and add MYLISP to the Trusted Locations list as I showed in post 7
  • Move my copy of SHLM.lsp to that folder.
  • In AutoCAD, start CUI
  • Navigate to the button that will call your routine.
  • For the command I suggest:  ^c^c(if (null c:shlm)(load "SHLM"));^PSHLM;
Close the CUI and try the button.
John Vellek
Message 13 of 23
Alfred.NESWADBA
just to add to
...and watch the command line, what it reports!
- alfred -
Alfred NESWADBA
Message 14 of 23
When I place that code snippet into the button, (and even when I try variations on it), the script will not come up.
I placed "c:/structural/system/lsp/" which is where the code sample is into the "Trusted Locations".
When you click on the button, nothing at all happens.
Message 15 of 23
The command line reports absolutely nothing.
Message 16 of 23
john.vellek
Please attach the file so I can take a look at it.
John Vellek
Message 17 of 23
Meaning,
does it involve really sophisticated knowledge of either the hardware or of the design of Autocad?
if it is just something trivial that I overlooked, then I am willing to spend some time reading up on how
to figure it out.
Message 18 of 23
john.vellek
HI lgojer123,
The steps I outlined should work for you as they did on my system. Without looking at the file now I am at a loss on how else to direct you. If you attach it I can play with it a bit to see what might be causing the problem.
BTW, please don't keep changing the subject line of your posts. It is hard for those of us following the thread when it changes.
John Vellek
Message 19 of 23
The file must not be reaching you.
Message 20 of 23
john.vellek
Hi @Anonymous, Are you attaching the file to your post? Try putting it in a ZIP file first and then attaching. if you check your posts you will be able to see if the attachments stuck
Some users complain that their firewalls block the attachments
John Vellek
