Tool Palettes
Tool Palettes
Message 1 of 11
Tool Palettes
Can someone help, I create a tool palette, and group of tool palettes but when I close AUtoCAD 2017, and reopen my tool palettes are gone?
NEED some advice, ideas or things to try?
Lee
Replies (10)
Message 2 of 11
pendean
Community Legend
Community Legend
Save your workspace after the TP creation perhaps?
Message 3 of 11
Tried this unfortunately still no joy.
Message 4 of 11
Alfred.NESWADBA
may be a restriction of permissions. Does the same happen when you start AutoCAD as admin?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 5 of 11
Again still no joy
Message 6 of 11
Alfred.NESWADBA
then try to create a new Windows user on your system, login with that account, turn off antivirus software and try the same again.
Also verify with your admin which folders he is protecting from being modified.
- alfred -
Alfred NESWADBA
Message 7 of 11
dont think this is a rights issue as i am the admin on my machine.
Message 8 of 11
Alfred.NESWADBA
To be admin does not mean you start software with admin-permissions.
And to create a new user account makes sure that no user profile conflicts exists, that's why I was suggesting that way.
- alfred -
Alfred NESWADBA
Message 9 of 11
I just replied to a very similar post to this, so let me ask, how are you creating your tool pallets?
If you make them by the "drag and drop" method (that is, taking a pre-made one from a windows explorer window, and dragging it into your drawing), that's the issue. When you "drag and drop" files, AutoCAD doesn't read them from the file you drug it from, instead, it creates a temp folder, stores the files to be transferred in that temp folder, then imports them into AutoCAD from there. The big issue with that is that temp folders get deleted every time the computer gets turned off, so AutoCAD no longer has a valid path.
If this is your issue, you have to create the pallet from opening content center, finding the files containing the information you want to import, then drag and drop from the content center.
Message 10 of 11
Hi there, no i have the issue if I
* Right Click the Tool Palette
* Customise Tool Palettes
* Add a new palette
* Then create my commands on the palette
AutoCAD doesnt seem to store the changes.
Regards
Lee
Message 11 of 11
john.vellek
Hi @Anonymous,
I found this article that describes the same problem (I think). Give it a try and let me know if that helps.  It does refer to a permissions problem so I am not 100% convinced it will do the trick but my fingers are crossed.
John Vellek
