How to color up this design
Hey,
This is probally a noob question but I need to color up this design but I don't know how.
If anyone would take the time to help me, I would really appreciate it.
pendean
Community Legend
Community Legend
define "color up" for those of us that don't work in your office of have access to your requirements: your file only contains flat 2D line with an elevation/height setting so there is nothing to "color up" if you don't want to just use PROPERTIES command to change the colors of the lines you've drawn.
Sorry for the unclear question, I want to make the logo a Solid item so that the red is not only seen from the side but also from the Top and bothem.
Sorry If I am doing it all wrong, I am new to autocad.
Patchy
BHATCH command or 3d ?
Alfred.NESWADBA
instead of using _EXTRUDE to give arcs or lines a thickness create closed polylines from your objects (command _PEDIT and option _JOIN).
When you now use _EXTRUDE with closed polylines you get 3D-Solid objects (which do have caps.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Dont really know the difference, but that is exactly what i want!
Thx
