My AcTpTools.atc Tool pallete somehow got corrupted and it is empty now. 😞
Is there a way that I can download the tool pallete from Autodesk?
Thanks!
Hi Crios;
I am not sure what OS or product you have, you should include that information next time, if the below doesn't fix the issue.
First, you should try resetting AutoCAD (or similar product) to defaults:
How to reset AutoCAD to defaults
If that doesn't help, check this out:
If neither of those things help, post back here with your exact OS (IE Windows 7), product and version (AutoCAD 2015) and anything you can think of that you have done recently that might have affected the product, like an Operating System upgrade or new program install.
I already got them to work.
And sure next time I'll let you know that I have Windows 7 and it was for AutoCAD 2013...
Excellent!
What got it working, if you do not mind my asking?
This is so subsequent Forum users can benefit from your experience.
Please post back if you have a minute.
I used some recommendations from Autodesk: Exchange tool palettes between different versions of AutoCAD _ AutoCAD _ Autodesk Knowledge Network.
And I really used the files from the other AutoCAD 2013 seat we have. So far is working...
