Hello @mention,
Welcome to the Autodesk Community!
To build on pendean's post,
The design center might help you save some time once you have it set up to meet your needs.
" With DesignCenter, you can
- Browse for drawing content such as drawings or symbol libraries on your computer, on a networked drive, and on a web page
- View definition tables for blocks and layers in any drawing file and then insert, attach, or copy and paste the definitions into the current drawing
- Update (redefine) a block definition
- Create shortcuts to drawings, folders, and Internet locations that you access frequently
- Add content such as xrefs, blocks, and hatches to a drawing
- Open drawing files in a new window
- Drag drawings, blocks, and hatches to a tool palette for convenient access
- Copy and paste content, such as layer definitions, layouts, and text styles between open drawings
The DesignCenter Window
Use the tree view on the left to browse sources of content and to display content in the content area on the right. From the content area, you can add items to a drawing or to a tool palette. A preview or description is displayed for selected drawings, blocks, hatch patterns, or xrefs.
The DesignCenter toolbar controls navigation and display of information in the tree view and the content area. The same navigation and display options are available on the shortcut menu. Right-click in the content area to display the menu.
As with other dockable windows and palettes, you can resize, dock, and anchor DesignCenter. Many of these options can be set selecting an option on the shortcut menu. "
I reference this AKN article: About DesignCenter; About Adding Content With DesignCenter
Post back and let me know if this helps.
Thanks.
Sarah Emmsley
Technical Support Specialist
