Tool Palette Tabs order not updating
I'm using Autocad 2016 and I have my tool palette on the network. I am able to add tabs and groups and it updates just fine. The problem is when I rearrange the order of the tabs it doesn't update on the server. (The AcTpCatalog.atc file)....  It does however show up correctly on my computer. Any help?
Matt
My mistake....won't even keep the order when having the tool palette on my own C drive.... I've saved my workspace and saved my profile. Still not keeping my order and updating the .atc file...
Well after further investigation, you can only set up the order of tabs the first time you save the .atc file.  You have to use an XML editor to modify the tabs order for a network tool palette path to work.
seanp.fahey
Thank you for this posting as this saved me quite a bit of time.  XML Note pad came in quite handy and was a breeze to update the tool palette
