I am not super versed with using the autoCAD tool palette and am having an issue figuring out the behavior of this hex socket bolt (side) I am inserting into a drawing. When I insert the first bolt I get the behavior I would expect. With OSNAPS turned on I am able to insert the bolt at a location in my drawing using intersecting OSNAPS and the insertion point of the bolt. When I try to insert a second bolt the behavior is different though. It is automatically deactivating OSNAPS when I hover over the insertion point and moving the bolt to random spots on my screen. I can see it’s highlighting lines and when I move the bolt to a location away from the side of the hole it will highlight the hole. I am unsure why this happens only for the second bolt though, and why I am unable to just use ONSNAPS to insert the second bolt. Can someone please explain this behavior? And is there a specific setting associated to this behavior?
I am running autoCAD 2024.1.2
