Hey all,
So my goal is to create a tool palette with all of the different legend blocks for mechanical work.
The blocks have all been created before I started working here.
I have the actual palettes created. Most blocks insert correctly (sizing, etc) but some seem to come in way to large. For example a 2x4 light will insert at 50x100....
I have made sure the actual block files are the right size, my INSUNITS, INSUNITSDEFSOURCE, INSUNITSDEFTARGET are all set to 0 for the sake of switching between imperial and metric.
If anyone has a fix it or ideas on what needs to be changed it would be a great help!
-Garrett
So...
Is it sized correctly in the new File?
Not one of your stock templates. A new blank empty drawing file.
Find out if it is something to do with the Template first.
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
Can you post one of the offending blocks?
