Announcements
Title Mark
Title Mark
I need to insert title mark in my layout.
maratovich
Write in detail. Attach the sample.
Software development
Automatic creation layouts and viewport. Batch printing drawings from model.
www.kdmsoft.net
john.vellek
Hi @Anonymous,
Is this mark an AutoCAD drawing or is it an image?  If it is a drawing, simply use the insert command to bring it into your file. If it is an image, try using an IMAGEATTACH.
I am happy to take a closer look if you can share some files.
If your data needs to be private or confidential, please email it directly to me at john.vellek@autodesk.com and please include a link to this thread in your email.
John Vellek
Kent1Cooper
@john.vellek wrote:
Is this mark an AutoCAD drawing or is it an image?  If it is a drawing, simply use the insert command to bring it into your file. ....
Better yet, if a "title mark" is what I would call a "title block," use XREF to bring it in, rather than INSERTing it.  Then, when anything in it changes [such as the name of the project, or your office address or telephone number, or the positions of some elements in it, etc.], you can change it in only the one source drawing, and it will automatically be updated in all  eXternal REFerences to that drawing, in all  Layouts in all  other drawings.
Kent Cooper, AIA
john.vellek
Hi @maratovich,
I am coming back to your thread to see if the issue or question you posed has been resolved.  If so, please mark the post or posts as Solution(s) to help others find the answer quickly. If your issue persists, please give me a bit more detail on this issue so we can continue to work towards getting this solved.
John Vellek
