Title block text not appears in paper space
jayhar
Advisor Advisor
Message 1 of 22
jayhar
Hi all,
In title block text not appears in paper space, font not missing all are checked. QTEXTMODE  and QTEXT also checked. all layers are on include VPfreeze. working in laptop with AutoCAD 2016 version, only this system cannot see text another PC are working.
Jayhar.M.J
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly.
Replies (21)
Message 2 of 22
ВeekeeCZ
VPLayer, annotation scales... checked?
Message 3 of 22
jayhar
yes
Message 4 of 22
ВeekeeCZ
Remove the rest of the content from your drawing and post the dwg to take a look.
Message 5 of 22
jayhar
Message 6 of 22
cadffm
Not just checking, also set it well, it's ON!
Start QTEXT, Press [F1] to learn about it.
(and why you talk about "in Layout", no Text, not Style , no where you can see a text -
just the QText rectangle. So it it better to write "all Text, all space, all styles..")
And think about whether it really has to be in 2004 format
I refrain from trying to explain to you what that means and what has followed.
Sebastian
Message 7 of 22
jayhar
If you understand my situation help it,
or
do your job, insulting me through private message that was your job
Message 8 of 22
ВeekeeCZ
The thing about QTEXTMODE is that the feature has to be UNchecked!!
That's what @cadffm was tried to say!
Message 9 of 22
jayhar
<<<<<<< The thing about QTEXTMODE is that the feature has to be UNchecked!!
That's what  was tried to say!>>>>.
Ok
i convert text ( TXT2MTXT) one by one then it appears, have any .Lsp ???  to change full single line to multi line text
Message 10 of 22
ВeekeeCZ
OK. To be clear. Set qtextmode to 0 and perform REGENALL
Message 11 of 22
jayhar
Not working
Message 12 of 22
cadffm
or
Wow. 🤔
I helped, i didn't tried to  insult you, then these words, wonderful.
I'm also open to excuses when you're ready.
Sebastian
Message 13 of 22
cadffm
@jayhar wrote:
Not working
Make your Screenshot of the whole Program,
with commandline or [F2] visible,
so we can see the log sequence and the drawing editor.
Befehl:
Befehl: _QTEXT
Modus eingeben [Ein/Aus] <Ein>: _off
Befehl: _REGENALL
Regeneriert Layout.
Regeneriert Modell.
<screenshot, whole program window and Textwindow or commandline from "Command: QTEXT" till "Command:">
Sebastian
Message 14 of 22
ВeekeeCZ
It is for me. Nice and slowly HERE
Not sure what can be wrong if it's still not. I would set qtextmode, restart acad, reset pc... you'll see.
Message 15 of 22
jayhar
some text appears
Message 16 of 22
ВeekeeCZ
Then it's just about regen. Step in a small VP and do regen. See HERE
Message 17 of 22
cadffm
@cadffm wrote:
Command: _REGENALL
Or use REGENALL instead of regen.
Regen current Viewport
[F1] -REGEN
Regen all Viewports
[F1] - REGENALL
Sebastian
Message 18 of 22
pendean
Community Legend
Community Legend
See attached.
Message 19 of 22
jayhar
please upload AutoCAD 2013 format
Message 20 of 22
Alfred.NESWADBA
_REGENALL is what you need (and which is already suggested multiple times here), but also take care ... you are using fonts which are not TTF and also not SHX:
This could be an issue for 2013.
In case you don't see all text content after disabling QTEXT please start command _STYLE and change the text-styles to TTF- or SHX-fonts.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
