AutoCAD Forum
Title Block file is read-only when XREF'd
4 REPLIES 4
barskyd
309 Views, 4 Replies
Hi all,
There's a title block that's being referenced by all the drawings in a set, and whenever anyone on my team tries to edit the title block file (including myself) it says that it's in use. When all files are closed that reference the title block, then it becomes editable.
Folder structure and title block file all have "Read-Only" turned off.
Any ideas?
4 REPLIES 4
Patchy
in reply to: barskyd
If others are using the title block as xref then that's how it works. READ ONLY
Same as Image.
barskyd
I've always been able to edit referenced title blocks before. In the past, once the file was saved all users get a "Reference Out of Date, Click here to Refresh Xref" message.
pendean
What is literally everyone's settings in OPTIONS here? It only takes one to be different...
barskyd
in reply to: pendean
Thank you so much!
Technology Administrators
