Tiling of a material
pjgadsdon
pjgadsdon
Hi
I created a sheet material (ply) and it looked perfect but since I made my material bigger it now looks like it has tiled. Is there anyway I can make this look correct
Cheers, serious newbie here
imadHabash
I think that you need to control the texture scale.
Imad Habash
pjgadsdon
I had a look but unsure how to do this
Thanks again
imadHabash
pjgadsdon
Thanks but my material as I created it doesn't have a scale
Alfred.NESWADBA
every time there exist some settings deep inside an object configuration it's always a good tip to send a drawing with at least one object we can then use to test.
In case you have your own image for texture mapping, then please upload this too.
This makes it much easier to see where exactly you are missing a setting.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
pjgadsdon
I got it
I will send the drawing next time
