The problem of mirroring the text in the other blocks that are mirrored when writing inside the block
muhendisleman
muhendisleman
Hello everyone,
I created a blok and mirrored it at some places in a drawing. Then i wrote text in block and saved. When i turned the drawing, I see that text mirrored at some places. How I can solve this problem? Thanks for your help.
Moshe-A
@muhendisleman  hi,
Texts objects inside block flip with mirrored blocks and the only way to overcome this is to design a block with attributes (instead of text). mirrored attributes controlled by MIRRTEXT system variable, by default it is set to ON (1), which means attributes in mirrored block are flipped. if set to OFF (0), they stay readable 😀
cheers
Moshe
Kent1Cooper
@Moshe-A wrote:
... the only way to overcome this is to design a block with attributes (instead of text)....
And note that you can make Attributes with constant values, so you won't be asked for values to put in them every time you Insert such a Block.
Kent Cooper, AIA
muhendisleman
Thank you for your help. I’ll try it.
muhendisleman
Hmm Its a good information. Thank you so much.
