The plotter configuration does not support the paper size
monika.adaa
Observer Observer
monika.adaa
Observer
Observer
Problem: when I' m trying to plot the frame , the frame appears:
the plotter configuration does not support the paper siże of the current layer. What do you want to do?
I' ve coppied a piece of drawing from anorher file. Now I don' know how to fix it . I can print another files normally, only this file is corruped.
Here is a photo from printer options. Should I change sth?
rendermaster
the image you posted is just a search path location of your printer configuration. anyhow, it could be that the installed printer or printer configuration save along with the file is different from the computer you are using. to check, see image below:
Ronel Katigbak Pabico
3D Generalist / Animator / Renderer/ Graphics Designer
Autodesk Student Ambassador Platinum
YouTube Channel l Linked l Facebook l Blogs
