F8 - orto at the same time
Dear Autudesk Team,
this is another problem - while I'm drawing using for exaple line, poliline or another function and at the same time want to use function F8 (orto) my AutoCad crash'es. It has been happening since 2 monthss.
Best regards,
Bartosz Radzki
[email protected]
+48 796 056 688
imadHabash
Hi and Welcome to AutoDesk Forum,
Try to change TEMPOVERRIDES system variable from command line.
Imad Habash
john.vellek
Hi @Anonymous,
This behavior first presented itself with Windows 10 Anniversary update. Is this the version of operating system you have installed? If so, turn off the TEMPOVERRIDES (set it to 0) to get things to work properly.
Another option is to roll back the update if your system will allow it.
John Vellek
john.vellek
Hi @Anonymous,
I am checking back to see if my post or @imadHabash's helped you with your problem.
Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please select the Accept as Solution button if a post or posts fully solved your issue or answered your question.
John Vellek
