AutoCAD Forum
The image tab not showing up
14 REPLIES 14
Message 1 of 15
mingw5216
407 Views, 14 Replies
I attached an image from my computer and I'm trying to hide the image. Normally I would select the image and the image tab will appear at the top and I can click the 'show image' button. But when I selected the image, the image tab doesn't appear.
14 REPLIES 14
Message 2 of 15
paullimapa
in reply to: mingw5216
not sure why the image panel is not automatically showing on your ribbon
have you tried restarting autocad?
you can also select Show Image options on the Properties window:
Paul Li
IT Specialist
@The Office
Message 3 of 15
Valentin-WSP
@mingw5216 ,
@mingw5216 wrote:
I attached an image  ... when I selected the image, the image tab doesn't appear.
Was the image attached [Insert] as Reference or OLE Object?
Unlike a reference, OLE objects will not show on the ribbon. Place the OLE on a layer to turn ON/OFF.
If it was reference, then use the link below to troubleshoot the tab not showing on the ribbon:
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
Emilio Valentin
Message 4 of 15
mingw5216
in reply to: paullimapa
I tried closing Autocad and opening it again but it still has the same issue. When I go to properties, I don't see the hide image option either.
Message 5 of 15
paullimapa
the Properties window shows what you selected is a Block and not an Image:
Paul Li
IT Specialist
@The Office
Message 6 of 15
mingw5216
in reply to: Valentin-WSP
It was actually imported as a PDF using the PDF import option, sorry for the confusion.
Message 7 of 15
mingw5216
I actually imported it using the 'PDF import' option.
Message 8 of 15
paullimapa
If you have a PDF editing program, you can always open the PDF & save it as an Image file and then ImageAttach that into AutoCAD. Then you should be able to use the Hide/Show feature.
Paul Li
IT Specialist
@The Office
Message 9 of 15
mingw5216
Okay, I was watching an autocad tutorial course and the instructor imported it as a pdf and he's able to select it and the image tab appears. It's not a big deal for me, I was just wondering if there's a way to get it to appear. But thanks for the help anyways!
Message 10 of 15
paullimapa
Since I don't have your PDF file you're Importing, my best guess is that during the PDFImport process, the tutorial had under Import options the Import as Block option unchecked. Then if there are any images within the PDF, it'll come in as an image for you to select to toggle Hide/Show. But if the Import as Block option is checked then your PDF will come in as a BLOCK which is what is happening based on your screenshot. Now if this is the case, you can select the BLOCK and Explode it. Then you can select any images that might have been within the PDF to Hide/Show.
Paul Li
IT Specialist
@The Office
Message 11 of 15
mingw5216
Yes, that is what happened. The tutorial had the import as block option checked but for some reason the instructor can select it and the image tab appears. I will try to explode it and see if that works.
Message 12 of 15
cadffm
If it was "imported as block"
he's start Refedit, Bedit or Explode before selection.
Share the tutorial link, if this is an online tut
Sebastian
Message 13 of 15
mingw5216
in reply to: cadffm
It's from this site called SourceCAD. You would need a subscription to be able to assess the materials that I have. But I exploded the block and now it works.
Message 14 of 15
mingw5216
I exploded the block and it works now. Thank you so much!
Message 15 of 15
paullimapa
You’re welcome…cheers!!!
Paul Li
IT Specialist
@The Office
Technology Administrators
