We are currently experiencing an issue impacting some Autodesk Products and Services - please refer to the Autodesk Health Dashboard for updates.
the file or directory is corrupted and unreadable
cwendling26
Message 1 of 20
cwendling26
My AutoCAD stopped working one recent morning. I tried to start the program and got the error "the file or directory is corrupted and unreadable". I tried uninstalling everything and re-installing, but the same problem persists. Please help!
Replies (19)
Message 2 of 20
Alfred.NESWADBA
can you please show a screenshot from that message (and the screen in that state)?
For me it is not clear if you have one defect file or AutoCAD has issues with reading it's program files.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Message 3 of 20
s.borello
Did you do anything recently to your PC that may have caused this?
Message 4 of 20
cwendling26
It happens when I try to open any files, or even just start autocad on its
own
Message 5 of 20
Alfred.NESWADBA
- alfred -
Alfred NESWADBA
Message 6 of 20
cwendling26
it happens when I try to open .dwg files, but also just trying to start autocad itself.
Message 7 of 20
Alfred.NESWADBA
ok, does that directory exist (can you use your Windows Explorer to go into that folder)?
If yes, does the file ACAD.EXE exist in that folder? And how many files do you have in that folder?
Can you create a new textfile inside that folder?
- alfred -
Alfred NESWADBA
Message 8 of 20
cwendling26
Message 9 of 20
cwendling26
Here is file location, 742 items, cannot create new textfile
Message 10 of 20
Alfred.NESWADBA
does an ACAD.EXE file exist inside that folder?
If yes:
  • what happens when you double-click this file?
  • what happens if you right-click that file and use option "start as administrator" in the context menu?
- alfred -
Alfred NESWADBA
Message 11 of 20
pendean
Community Legend
Community Legend
You need to remove and reinstall 2018: you may even have a bigger problem developing, by chance is your computer starting to freeze at weird moments these days too?
Message 12 of 20
cwendling26
i've uninstalled, using microsoft's troubleshoot uninstaller also. deleted
all remaining files that i could fine and cleared everything the best i
could before reinstalling. the same error comes up again after all of this.
i've had my PC crash a few times out of the blue and shut off over the past
few weeks.. oh no...
Message 13 of 20
Alfred.NESWADBA
have you tried my last questions?
- alfred -
Alfred NESWADBA
Message 14 of 20
cwendling26
same error message when i click on acad.exe "file or directory is corrupted
and unreadable"
different error message when I right click run as administrator (see
attached)
[image: Untitled3.png]
[image: Untitled4.png]
Message 15 of 20
cwendling26
also maybe worth mentioning: recap and revit were starting up fine
Message 16 of 20
Alfred.NESWADBA
Sorry, no images arrived here (please do not use your mail system to answer, instead use your Internet Browser to reply, there you can add images).
- alfred -
Alfred NESWADBA
Message 17 of 20
pendean
Community Legend
Community Legend
>>>...i've had my PC crash a few times out of the blue and shut off over the past few weeks.. oh no……<<<
You have a damaged sector on your harddrive and possibly overheating I suspect, you'll see more random freezes of your computer as the days go by.
You want to backup your system ASAP then take it to a repair shop real soon.
Good luck.
Message 18 of 20
cwendling26
Message 19 of 20
Alfred.NESWADBA
I guess @pendean is correct, your harddisk seems to have issues.
Create a new backup (do not overwrite your last one, just to make sure that files, that maybe already corrupt, do not overwrite the good ones).
Then you can run checks on your disk.
- alfred -
Alfred NESWADBA
Message 20 of 20
lopezmariaa1010
Community Visitor
Community Visitor
I think you should first check the connection between your drive and PC to fix the unreadable error. Let’s check out the below easy fixes to overcome the file or directory is corrupted and unreadable issue:
  • Connect the USB flash drive to another USB port
  • Try to simply connect your USB flash drive to another computer
  • Replace a USB cable.
I hope, this fix may help you to solve the unreadable error. Good luck…
