The equivalent command to the “Isolate” while working with layout viewports,
JamaL9722060
JamaL9722060
I couldn’t figure out the equivalent command to the “Isolate” while working with layout viewports.
For example, in the attached screenshots, I wanted to isolate one layer in SOLE viewport. Using the “isolate” command will affect other viewports!
How this might be performed?
Thank you
Best
Jamal
Jamal Numan
nestly2
LAYISO > [S]ettings > OFF > VPFreeze
pendean
Community Legend
Community Legend
ISOLATEOBJECTS command is not viewport-aware: neither is HIDEOBJECTS command.
In addition to LAYISO noted above, LAYOFF and LATFRZ can also be set to be viewport-specific as well. if you need more options later on.
JamaL9722060
Many thanks Nestly. It works fine.
Does this mean that the “Turn On\Off” command can be exactly the same as “Freeze\Thaw” if the setting is chosen to be “VP Freeze” (attached)
Jamal Numan
nestly2
Anything that changes a Layer's ON/OFF state is a global setting that will affect the display of those layers in all viewports.  VPFreeze/VPThaw only affects the display in the current Viewport.
JamaL9722060
This is what I wanted to concluded.
If the “Off” command (attached) is set to have the “VP Freeze” option then it will affect only one viewport and thus it will behave as the “freeze” command.
Am I correct?
Jamal Numan
