The application has failed to start AutoCAD 2016
C:\Program Files\Autodesk\AutoCAD 2016\acad.exe
The application has failed to start because its side-by-side configuration is incorrect.Please see the application event log or use the command-line sxstrace.exe tool for more detail.
Whenever I start a program I got this error.
I have done uninstallation and re-installation and still this is happening.
Please advise.
Thank you.
Slawomir_
VinodBalasubramanian
Autodesk Support
Autodesk Support
Hi Jerome,
Did you manage to try the following suggestion as it could fix your problem,
http://knowledge.autodesk.com/article/Error-The-application-has-failed-to-start-because-its-side-by-...
Hope it helps.
Vinod Balasubramanian
AutoCAD Industry Support & Escalation Lead
WHat I did was I used the Uninstall Tool from the Windows -> All Programs then I re-install the programs AutoCAD Plant3D and AutoCAD Mechanical. Now, I can use my AutoCAD.
Thank you guys for sharing the link. I will consider that in the future.
