Thawed Layer not showing in Model space
Dwg from Architects, Room numbers only showing in paper space. The layer is thawed, I don't know why it isn't showing in Model space.
Alfred.NESWADBA
first ... please turn on layer 0
Maybe the text objects are placed in paperspace and not in modelspace?
If that does not help then the text object might be set to annotative while CANNOSCALE is set to a scale which the text has not assigned.
If we could access the dwg-file the solution would come within minutes 😉
[EDIT]...oh, missed the dwg file already uploaded, sorry [/EDIT]
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
user181
Hi @Anonymous   when in model space on the status bar either change the annotative scale to 1/8"=1'-0" or click the button to always show annotative objects
ChicagoLooper
Your viewport scale is set to 1/8" = 1'-0".
To make the labels appear in modelspace, go to modelspace and click this buttom and make it highlight blue:
Chicagolooper
imadHabash
In model space change ANNOALLVISIBLE system variable = 1
Command: ANNOALLVISIBLE
Enter new value for ANNOALLVISIBLE <0>: 1
Imad Habash
