text transparency
text transparency
text transparency
hi i have a drawing file and all the text is transparent in acad2016.....in earlier release it was fine....ive tried changing the style settings/colours/attributes etc to no avail....see screen grabs, when i highlight you can see it but otherwise its just doesnt show up.  when i plot the file it show up fine, just not visible on screen? any ideas how to remedy?
JDMather
Can you attach *.DWG file here?
hi, copy of file attached....to add, it doesnt happen all of the time.....i have restarted my pc and acad and now i can see everything !! so not sure if the glitch might be somewhere else opposed to the text settings!
Alfred.NESWADBA
except of that the logo is an unnamed block and _AUDIT shows an issue with a hatch I can't see anything wrong.
Next time you have the display problem
  • disable your hardware acceleration
  • when the objects are selected, use command _DRAWORDER to bring them to front (if there is an object (white) on top of the selected geometry)
  • at least close and reopen the drawing.
And if nothing of that does work let us know that.
I guess it's not possible for us to help (more than guessing) if the problem is not reproducable. But guessing can be one option so you have suggestions what to try when the issue appears again.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
