Text styling on imported PDF projects
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Occasionally I'll have to use a pdf and import assets into an AutoCAD project where all of the font is the wrong format. For example: the color will be wrong even after changing the properties tab settings and I've had to go into the text editor tab for each individual line of text to fix the import. What options are there to update all of the imported text to be the right format other than having to do each line of text individually? Why is the text editor color over-riding the properties tab text settings? If the text is highlighted using text editor and the color is changed to red for example nothing happens when I try using the properties tab to change the texts color. The same can be said for the text sizing, as well as font. I'm not sure if it's because of a poor design flaw or if there's some workaround. Any input is appreciated on how to fix this issue.
