Text Size Issues
Text Size Issues
Text Size Issues
So in a nut shell, when I'm annotating, the text is the appropriate size I have it set to, but as soon as I click out to continue with something else the text changes to a crazy, large, size. This happens both when I'm using single line and multi-line. I've tried changing the size in properties, which works, but as soon as I move something or change anything it goes back to a very large size. As far as I can tell, there is no scale factor causing this. Please help, this is very frustrating.
PS: I'm working in RebarCAD, if that makes a difference.
Thanks.
john.vellek
HI @Anonymous,
I see that you are visiting as a new member to the AutoCAD forum. Welcome to the Autodesk Community!
Is the Text Style that you are using set to be Annotative?  Is it possible to share a sample drawing file with me so I can see what might be going on with the text size changing?
John Vellek
imadHabash
i suggest to check these two icons in the status bar ( see below image )
also you may need to check SELECTIONANNODISPLAY system variable value.
Imad Habash
beyoungjr
When you are creating a multiline text object, AutoCAD attempts to show you the text as readable when you are typing it.  Once you exit the text editor the text will quickly enlarge or shrink to the size it is supposed to be.  You can use the MTEXTFIXED variable to control that display so that the text display while typing is sized as your font setting dictates.  The variable is on/off (0 or 1).
Is this what you are experiencing?
Blaine Young
Senior Engineering Technician, US Army
john.vellek
Hi @Anonymous,
I am checking back to see if my post or others helped you with your problem. Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
John Vellek
Hello, it took me a while to finally realize what was causing this issue. I was annotating within a view port, to correct the issue I hovered over the CADS-VPM, selected configuration options, and selected "Never rescale and never ask again" in the TEXT/D TEXT\ M TEXT Scaling Options drop down box. Haven't had an issue since. Again, sorry for the long wait.
