Text automatically changing height without my doing.
So in a nut shell, when I'm annotating, the text looks the size I have it set to, but as soon as I click out to continue with something else the text goes to a crazy large size. This happens both when I'm using single line and multi-line. I've tried changing the size in properties, which works, but as soon as I move something or change anything it goes back to a very large size. I've also tried doing this using the STYLE command, but it has the same result as when I change the height in properties. As far as I can tell, there is no scale factor or override causing this. Please help, this is very frustrating.
PS: I'm working in RebarCAD, if that makes a difference.
Thanks.
imadHabash
since we're here in AutoCAD Forum .... would you please attache here your CAD file for testing if possible ?
regards,
Imad Habash
Here you go.
imadHabash
i open your drawing and there is nothing weird. even i didn't found your text that appeared in your first post ( Example ) . i notice that there is a small plans and big ones that 100 bigger, maybe your text style need to be review .
Imad Habash
The smaller plans were from pdf underlays, the larger ones I scaled to actual size. I believe the example text didn't show because I didn't save it to the file. I'll keep messing with it and hopefully figure out what's wrong. Thanks for taking a look!
john.vellek
Hi @Anonymous,
I see that you are visiting as a new member to the AutoCAD forum. Welcome to the Autodesk Community!
I looked at your file and when it opened, I was prompted about Proxy Objects. It appears that you are using a re-bar add-in.  Can you uninstall this add-in to see if affects the text issue?  I was unable to duplicate the issue you show.
Can you try wblocking or copy/pasting your model into a new file to see if behaves normally?
John Vellek
I unfortunately cannot uninstall the add in, but when I copy and paste it into another drawing it seems to work normally.
