text setting
text setting
text setting
where can i find text setting
Accepted solutions (3)
Type "STYLE" in the command line
imadHabash
Hi and Welcome to AutoDesk Forum,
as mentioned above you have to prepare text style or you can either from properties Ctrl+1 edit some text settings.
Imad Habash
john.vellek
Hi @Anonymous,
Welcome to the Autodesk Community!
To access your text setting you can use a variety of means such as from the Annotate Menu and the Text panel (click on the arrow next to standard to access the Style Manager
You can also type the command Style (or ST for short).
If you have a piece of existing text you want to adjust, select it and then rt-click to open Properties or use CTRL-1.
John Vellek
john.vellek
Hi @Anonymous,
I am checking back to see if my post or others helped you with your problem.
Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please select the Accept as Solution button if a post or posts fully solved your issue or answered your question.
John Vellek
