Hi @Anonymous,
Welcome to the Autodesk Community!
To access your text setting you can use a variety of means such as from the Annotate Menu and the Text panel (click on the arrow next to standard to access the Style Manager
You can also type the command Style (or ST for short).
If you have a piece of existing text you want to adjust, select it and then rt-click to open Properties or use CTRL-1.
John Vellek
