Text Script - Copy and Paste from EXCEL Not Working
jeremy.herman90
Message 1 of 9
jeremy.herman90
I have a spreadsheet with the following formula:
=CONCATENATE("TEXT ","J ","MC ",H1," 5"," 0"," TEXT")
This gives: TEXT J MC 384895.42,409157.73 5 0 TEXT
When I copy and paste the above into the AutoCAD command line, it gets me all the way to the rotation angle specified as 0, but still is waiting for keyboard entry of the text. I want it to input "TEXT" as well, but it isn't.
When I put the same command in a script file and upload as a script, it works. Any ideas?
Replies (8)
Message 2 of 9
fatal.error
Have you tried this?
(command "text" "J" "MC" "384895.42,409157.73" 5 0 "TEXT")
Message 3 of 9
jeremy.herman90
Hi, thanks for your reponse. It does not appear to have worked, see screenshot:
Message 4 of 9
fatal.error
Your "MN" justify is not a valid option, at least in my acad:
Please try MC as the code above.
Message 5 of 9
pendean
Community Legend
Community Legend
Fix your typo
Message 6 of 9
tramber
Our friend gave you some lisp....
You need to simulate one more space or ;
(look, the "_" stand for a space)
TEXT J MC 384895.42,409157.73 5 0 "MYTEXT"__
End
End
A double space is missing or a single one if you enter Return between two lines in a scr file...
Message 7 of 9
jeremy.herman90
Nice spot, I tried (with fix) but still did not work:
Message 8 of 9
jeremy.herman90
Apologies - it did in fact work. Just already had something in the same location from previous tries so was generating error. Many thanks!
Message 9 of 9
jeremy.herman90
Thank you for this. I would like to get this solution to work as well, as it lends itself to better spreadsheeting. I tried this:
EXCEL formula: =CONCATENATE("TEXT ","J ","MC ",H1," 5"," 0"," TEXT__")
Which gives: TEXT J MC 384895.42,409157.73 5 0 TEXT__
When I copy and paste the above directly from the EXCEL spreadsheet, I get the same probem as originally. Leaves me wanting keyboard input.
