Text override error
Text override error
Text override error
Using Autocad 2016 on a Mac. I'm simply using this program to change the text of the measurements from millimeters to inches. Now, when I submit the new measurement, it places it on top of the old one instead of replacing it. I tried resetting Autocad to default settings but that did not resolve the issue. I'm not savvy with coding or technical stuff so this was the extent of my knowledge on trying to correct this problem. I would appreciate any tips/solutions!
(See left lines on right image of the attachment)
gdefilo
Hi amanda,
looking at those dimension objects, it results there are at least 3 overlaid.
So, erase what you don't need, you will find the dimensions in inches.
Hope this helps,
Giancarlo
